What will run my cable speedo?
Old Apr 17, 2010 | 09:36 AM
millwright1999's Avatar
Default What will run my cable speedo?
I am just about to swap a LQ4/4L80E into a 74 Nova. I just realizes there is no place to hook up my speedo cable to the transmission. From what I have found I have a few options, 1) replace my speedo gauge with an aftermarket one, (autometer, dakota digital) or 2) replace the tail housing on the transmission. Both of which are over $500. I am trying to do this on a budget and don't want to spend that much on this part of the swap. What are my other options? What have some of you guys done for this? Any help would be great.
Old Apr 17, 2010 | 10:04 AM
crainholio's Avatar
Replacing the tailhousing w/ a gear drive creates a new problem...how to feed vehicle speed data to the PCM. Not recommended.
Common options are either #1 as you stated, or adding an Abbott box:
http://www.abbott-tach.com/cablex.htm
Old Apr 17, 2010 | 01:39 PM
flynbrian48's Avatar
Several guys on the HAMB board have gutted mech speedo housings and added elec. guts from a pick your part yard. Seems that'd be pretty easy. I'm using SW Wings series gauges in my project with a 4L60E, the entire set of 5 was only 300 bucks, and I needed 'em all anyway.
Old Apr 17, 2010 | 01:49 PM
L92Firebird's Avatar
um, what is the hamb board? do you have a link on gutting and converting a speedo?
Old Apr 17, 2010 | 08:41 PM
Pocket's Avatar
This is the easiest method, just expensive
3 wires and you're done. Speedo output from PCM, IGN and ground
http://www.atrol.com/cablex.htm
Old Apr 17, 2010 | 09:11 PM
Palomba's Avatar
it wont cost 500 bucks for a new speedo..... **** autozone has the half decent looking ones for 30
