Simple LS1 harness
Thanks
But if you just need a harness, painless is pretty easy for around $750.... plug and play
just need the correct grounds, batt 12v and switch batt 12v., Tach, VSS (if needed), fans (if used to the relay). Data port..... etc.. some extra relay and fuse.. and your done.
