Injectors problem or PCM?
If that's not the case, try the other color cks, and see if that's the problem???
I don't know the difference between a PCM and an E38 ECM. My engine computer has 2 connectors coming out of it, a blue one and a green one. Each has 80 pins.
Geezer, I thought the crank sensor was bad when I couldn't start the engine a couple months ago. I replaced the crank and camshaft sensors to be on the safe side. I could have definitely gotten the wrong part from the parts store. But, this crank sensor is the black one. My connector to the crank sensor is gray. (I'm just telling you this, because on some of the threads, people are saying that if the wiring harness crank sensor connector is gray, you should have a gray crank sensor.)
You said that VATS is off, did you turn it off yourself?
Do you have the intake tract complete from MAF to TB?
Yes, the intake track is complete. I bought a GM MAF since that didn't come with my engine. But the rest of it was stock on the engine and I haven't modified it.
Also check the GROUND for the engine harness that bolts to the block behind the power steering pump. This one gets missed a lot. Its for the coils mostly, but you never know..
Busta9876 makes some good points.
Also, there is a ground on the right side of the block on top behind the intake near the cam position sensor and also one on the back of the left head. Either one can cause major problems if loose.
I can look at what's on it, if you want. It's totally stock, bought new in 03/07.
BTW, this diagram is for a 2005 2500HD 6.0L 4L80E trans, but every wire that I needed from my 2006 harness was identical to this 2005 drawing. I don't think there was any variation up through the 2007 trucks (GenIII version, which should be what you have). I checked the database and the Blue #75 is also hot in run and start for the 2006 Silverado 1500. The database I use lags behind, and they haven't posted up the wiring diagrams for the 2007 model year yet, but I bet it's also the same.
I unhooked the MAF, and tried to start. Same thing. Still cranking and not starting.
The vacuum port on the back of the intake goes to my brake booster at this point.
I've got a ground wire near the power steering reservoir that is grounded to frame. Also on that point is the engine block, driver side head, and front axle.
FastKat, the C1.75 wire has been connected to the ignition relay and I don't get anything different when it's connected. I see it in the diagram that you sent. Thanks! It looks like I have all of the other wires exactly the same as that diagram.
99-2door, I have ground on the right side of the block on top behind the intake near the cam position sensor. I actually beefed up this wire in my wiring harness and gave it a solid ground back there.
I don't know about a ground being on the driver side head? Although I do have the rear part of the head grounded to the body firewall from there.
I have the SARVC still connected to my truck. I don't know if anyone's ever talked about using it during a swap, but I think it is used to monitor current consumption on the negative wire of the battery. Do I need it to run my engine or can I remove it?
Do I need a BCM?
Do I need to do a crank learn?
Could my PCM be stuck in some theft mode from trying to start it without the antitheft equipment installed even if I disabled the VATS?
Maybe it suggests a bad connection somewhere, or a connection in a bad place?
Maybe too much oxidation on a connection, or a loose connection on a major ground, power wire, or battery post?
Have you tried putting a load tester on the battery, or tested the battery voltage? There could be a bad cell in the battery.
Is something going on that could be causing this condition when the engine starts cranking?
Wiring is mostly brand new. The engine was pulled from a brand new truck with only 1 mile on it. Needless to say, the wiring harness has no dirt, grime or anything on it that could cause a bad connection. I've crimped 10 4AWG wires to ground everything to everything else. Body to frame to engine to transmission to axles. I've got 1 1/0 Ground wire from battery to the frame to engine block at a single point on the frame.
I've double-checked and triple-checked the wiring in the new wiring harness. I even have a spreadsheet on every single wire that is connected to the PCM and where it goes.
Guys, Thank you so much for helping me with ideas here. I've tried to cover my bases and it's good to know that we're on the same page.
This was a PCM for an automatic tranny and I removed the tranny in favor of a manual. I don't know what part that would play in everything. Do I need a segment swap?
I'll keep you updated and if you have any other ideas, shoot!
FWIW, the lady that parks next to me has a Saturn Sky... she just had her PCM replaced last Friday because it went bad (hardware failure).
