DIY ls2 harness Q
Old May 19, 2010 | 04:50 PM
Baynut's Avatar
Default DIY ls2 harness Q
Hi, I got an Ls2 and trans out of an 06 TBSS. I got lots of harneses that came with it... from inside and outside the veh. However I did not get the gas pedal nor the underhood fuse block. I plan to make the harness a "stand alone". my question is should I make my own fuse block or try to track one down. What veh's are compatible if I go looking at the junk yard. What gas pedal would work?
I did get the ECM and the TAC,
thanks so much in advance.
Baynut.
Old May 19, 2010 | 09:20 PM
aknovaman's Avatar
gt the schematics and make your own fuse block and relay panel. That way you will only have what you need not a bunch of extras.
Old May 20, 2010 | 11:16 AM
Baynut's Avatar
Thanks, I was just looking at the ls2 crate motor starter kit.
I don't think it's ideal for me cause it's not for 24x. My motor is 24x. But it does have 2x o2 plus MAF plus pedal plus a ecm... not sure about trans aprovisions but who knows. any input?
