I Need Help with fan wiring
Old May 22, 2010 | 12:39 AM
harrison's Avatar
Default I Need Help with fan wiring
I have a Rock Crawler running an 2002 LS1 and I need help wiring a single fan with an over-ride switch. I have been running a probe in the radiater as my Street&Performance harness did not come with a wire in the harness for a fan and I have decided to run it from the computer.
Old May 22, 2010 | 08:04 AM
harrison's Avatar
anybody?
Old May 22, 2010 | 09:45 AM
02NavyBlueZ's Avatar
More info on the Fan setup.... Is it a single speed or double speed fan A lot of swaps use the Ford Taurus Dual Speed Single fan setup is this what you have??? So you want to use the PCM to control the fan Im assuming you are going to add the pin/wire to the pcm? You also want an override switch for??? To turn on fans while vehicle is off? A lot of unknowns here, fill us in more and I will be glad to post a diagram for you.
Old May 26, 2010 | 10:02 PM
harrison's Avatar
One single speed Be cool fan. I have added the wire to the computer on the low speed side and after having it tuned today the fan is now set to come on at 180. I was wanting to use a override as my computer had the fan coming on at 217.
