PCM Plug question...
Old May 25, 2010 | 10:08 AM
jeepnut24's Avatar
Default PCM Plug question...
How do I get the gray plastic covers off of the PCM plug without breaking them? And then how do I get the blue and red covers off? I spent some time looking at them and cant figure out how they come off?
Old May 25, 2010 | 02:03 PM
poconojoe's Avatar
I take a small pair of needle nose pliers and wiggle the tabs until they release out, after you break a few, you'll understand how much pressure you can apply
The colored covers have lock tabs on the end of them, you push them in and lift the cover past them
Old May 25, 2010 | 08:11 PM
Pocket's Avatar
They're designed to be removed by pinching and pulling the covers off. Some come off without a fuss, some require encouragement. I use a soldering pick to pry them out. The worst to snap are the middle ones because no tool can fit in there
Another reason I like the Fwd connectors better, they have easy to remove covers and the connectors themselves are much better looking
Old May 25, 2010 | 08:22 PM
jeepnut24's Avatar
Are they the same otherwise? IE, can I swap them out and use teh car connectors?
Old May 25, 2010 | 09:24 PM
Pocket's Avatar
Yup, everything wiring related swaps in
Old May 26, 2010 | 09:15 AM
jeepnut24's Avatar
THanks. Im going to have to pick some up.
Any idea on where to find new pins, and possibly the part number? I would like to add a new pin for fan control.
Old May 26, 2010 | 10:02 AM
poconojoe's Avatar
I use mouser unless I only need a couple, then I go to the dealer
12084913
