Gauge cluster question
I know that this year they were still analog so everything goin to it has it's own wire to send the signal(Tach, Speedo, Temp..etc), how does the digital odometer work? If I'm correct it doesn't go through a BCM, the Gauge Cluster itself breaks down the VSS signal.
The car is a 1998 V6 Camaro that is getting a LS in it..we are trying to use the stock V6 Cluster for now just to see if it will work, maybe eventually upgrade to the V8 Cluster. I can get the info how to wire it, I'm just trying to understand how it works.
Thanks.
You guys keep saying 4k ppm signal..is that just for the auto, or is that the base line signal input?
