Check Eng Light Wiring
Old May 28, 2010 | 11:44 PM
JJFarmer's Avatar
Default Check Eng Light Wiring
Does the check engine light PCM wire put out 12v (+) or is it a ground (-) to turn the light on when needed? I got ready to wire it in and I didn't have any info on it. It's an 04 GTO harness and PCM.
Thanks
JJ
Old May 28, 2010 | 11:48 PM
ge_forcez22's Avatar
subscribed, I also need to know this. I have a positive/negative test light, if no one has posted by then I'll let you know.
Old May 29, 2010 | 12:05 AM
G-Body's Avatar
sawzall wielding director
PCM puts out a ground signal
Old May 29, 2010 | 12:16 AM
bagged67camaro's Avatar
most of the outputs from the ecm are ground. from what ive studied
Old May 29, 2010 | 08:18 PM
JJFarmer's Avatar
I check mine today, it is a ground (-).
