LS Accessory Drive System
Old Jun 3, 2010 | 10:22 AM
ItDoRun's Avatar
Default LS Accessory Drive System
Question. I'm about to purchase an L92 pullout for my 68 Camaro and will be changing the stock accessory drive system. I want to put the F-Body setup, but can't find where anyone sells the complete kit. I did find the one from Pace Performance but they claim it's from a CTS-V. It looks very similar to the stock F-Body, but my question is this. Will the stock balancer work with this kit? I'm assuming the car and truck versions have the same balancer, but am I wrong?
http://paceperformance.com/index.asp...&ProdID=199032
Old Jun 3, 2010 | 11:52 AM
lamdenali's Avatar
we use the F-body accesories bracket and it drop right in our 69 camaro. the other is the GTO accessories will work also on our other 69 Camaro
Old Jun 3, 2010 | 11:55 AM
deuce4935's Avatar
Truck balancers are different. If you want the fbody setup, try googling nook&tranny, they keep them in stock.
Also, GM has another, part number 19155067 which comes complete with everything, alt, ac, bal, EVERYTHING!
Old Jun 3, 2010 | 03:18 PM
garys 68's Avatar
Does your motor have VVT that you're keeping?
If so, I think you may have water pump clearance problems with different spacing.
