1999 LS1 in a 1969 chevelle.
Old Jun 7, 2010 | 03:15 PM
Miguel 69Chevelle's Avatar
Default 1999 LS1 in a 1969 chevelle.
Do I need to change anything on the motor before I try to put it in the chevelle?.....can any one help?....thanks
Old Jun 7, 2010 | 04:49 PM
rockytopper's Avatar
The oil pan will need to be swapped. also the a/c unit and alt should be removed for starters.
Old Jun 7, 2010 | 05:56 PM
deuce4935's Avatar
See the sticky at the top of the Conversions page..... This has been addressed time and again, particularly for the A and F body vehicles.
Old Jun 7, 2010 | 10:38 PM
bczee's Avatar
If you know what your doing and plan it out well. nothing really has to be phyically changed.. but it would be easier to considering the out come and problem you will encounter doing it that way.
Yes a f-body oil pan can fit.. but its a PITA and just easier to swap it for something else.
Some front accessories will fit without any problem.. but knowing how to do it will help. one way is to mount the engine a bit higher..
Area if you research to plan around.. Steering cross bar and front of the oil pan. F-body alternator, need to make sure you have clearance for the pulley and the steering box.
If you have factory AC, the Passenger Head and the firewall / AC box gets real close (or in my case inside the box, don't ask).
that should give you enough to research and plan..
let us know if you have any specific question.. cause we have already written all about it in the A-Body FAQ sticky...
good luck
BC
Old Jun 13, 2010 | 11:56 PM
71 chevelle's Avatar
I have the fitting that goes onto the fuel rail -6. PM you info and I will send it out.
