Power steering Question
Old Jun 9, 2010 | 11:09 AM
Bobby G's Avatar
Default Power steering Question
Is there a fitting you can use to be able to use the stock ls1 hoses on a 1980 Trans am
Old Jun 9, 2010 | 12:59 PM
Eric Anderson's Avatar
Not sure if the seeering gear is different in your TA than my 68 cutlass. In my conversion, I just cut off the flare and removed the fitting off the LS1 assembly and put back on the fitting that fit my steering gear from the original motor. I then just re-flared the tube. I didn't even do a double flare. The tube sizes were the same. Third season, no problems yet.
