Wiring diagram
Old Jun 10, 2010 | 12:00 PM
the_merv's Avatar
Veteran: Air Force
Default Wiring diagram
I'm looking for the diagram or schematic for the steering column connectors on a 1995 Z28 and a 1998 V6 camaro.
If anyone has any info it would help. Thanks.
Old Jun 10, 2010 | 01:27 PM
02NavyBlueZ's Avatar
What is it specifically that you are looking for (ex. Ign Switch/Turn Signal/Wiper etc..) Also what are you trying to accomplish, this will help in what exact diagrams you need.
Old Jun 10, 2010 | 04:00 PM
the_merv's Avatar
Veteran: Air Force
I'm looking for the Pinouts on the Connectors that hold the Wiring for the Turn Signal/Horn..etc. There is 2 Connectors on the Column, I have the IGN Switch already.
I''m trying to put a 1995 Steering Column in a 1998 Car and I want to make sure the wires line up.
Old Jun 10, 2010 | 05:01 PM
Looks like both used the same 11way connector
Pinouts look to be the same as well from the Turn/Hazard Switch Assembly.
Horn is a black wire that is not shown in the diagrams i attached.
File Type: pdf
File Type: pdf
Old Jun 10, 2010 | 08:10 PM
the_merv's Avatar
Veteran: Air Force
Cool, thanks.
