wide band questions
thanks
The Innovate one lets you record things like RPM, vacuum and if you hook a TPS up you can record throttle position too. It comes with software that makes it really easy to play back the run on a PC. it uses camera flash cards so no cables are needed to transfer files.
The LM2 also has a full OBDII scanner built in. It is not just a code reader, it is a full scanner with logging capability. I have never used that.
The unit is pretty nice. For the most part it has worked fine but it can be a little quirky. Sometimes is freezes up and has to have power recycled. There is a butt load of wires to hook to it and I am not 100% happy with the type of connectors they use. I am gentle with it cause it doesn't look like they will take a lot of abuse.
But having said all that I don't know how people tune a carb without some type of AF meter. They really do the job.
It also logs to a computer to show the engine action "over time". Had it installed now for several years.
