First start - no dbw pedal response??
Old Jun 25, 2010 | 02:38 PM
Racinjason424's Avatar
Default First start - no dbw pedal response??
Finally got her started.. Idles fine, but DBW pedal is unresponsive?? I have ECM, Harness, TAC module and Pedal all from 2004 C5 Vette. Only difference is I have an LS2 throttle body on the motor. It came with an adapter to connect directly to the stock harness, so I thought I was good to go?? Could the LS2 TB be the problem? I had Speartech mod the harness and ECM.. Appreciate any info.. Thanks, Jason.
Old Jun 26, 2010 | 01:21 PM
fast400's Avatar
Do you have your serpentine belt hooked up? I had the same problem. In my case I wanted to run the engine without the belt. If the pcm doesn't detect enough voltage from the alternator it'll go unresponsive. I hooked up the belt and everything was good.
Old Jun 26, 2010 | 02:42 PM
Yep, belt was on.. I had the motor running and idling, just won't do anything when you press the gas
Old Jun 26, 2010 | 06:27 PM
Old Geezer's Avatar
Any codes set?
Old Jun 28, 2010 | 11:16 AM
Lurk's Avatar
if it's a ktech adapter for the TB, they are wired wrong for that app, you have to switch 2 wires
search for more detail I don't have it memorized hahaha
either way, double check the wiring on that adapter. Also pull for codes if you can!
