Truck intake manifold.
Old Jun 26, 2010 | 02:37 PM
meaclez's Avatar
Default Truck intake manifold.
can you run a normal injector in these and use the stock rails or do u have to use an aftermarket rail aswell. the stock truck injectors are real short
anyone?
Old Jun 26, 2010 | 02:43 PM
code4's Avatar
anyone?
What is a normal injector? I run mototron 60's in mine which are taller & take a different plug. So I just used some spacers & longer bolts to raise the fuel rails. Then I had to rewire the harness plugs with the correct connector.
