Need advice
Old Jun 29, 2010 | 04:10 PM
boosterror's Avatar
Default Need advice
I have a 94 isuzu pup I want to do an ls1 swap with 6speed. I'm going to buy a wrecked car so I have everything I need. My problem is that the truck has a cable clutch what are my options use the hydrolics of the t56
Old Jun 29, 2010 | 04:57 PM
SSilver's Avatar
used this for my 5.3 in my 1978 jeep. Works great and you could probably adapt it to work.
http://www.novak-adapt.com/catalog/kit_hcrc.htm
Old Jun 29, 2010 | 04:58 PM
SSilver's Avatar
oh you could probably make all the stuff from the t56 work....not 100% but I'm sure someone else will chime in.
Old Jun 29, 2010 | 07:15 PM
boosterror's Avatar
I don't think that's going to work
Old Jun 29, 2010 | 07:33 PM
Marcello7x's Avatar
Get a pedal assebly from a camaro or bird and cut the clutch pedal off, mount to firewall, and run gm master and slave and your good to go! Or just use the whole 3 pedal assebly.
Old Jun 30, 2010 | 07:49 PM
boosterror's Avatar
I might do that couse I'll have the whole car
