5.3l dies when put in reverse
Old Jul 2, 2010 | 11:35 PM
Mtrhd329's Avatar
Default 5.3l dies when put in reverse
I have what sounds like a pretty wicked vaccuum leak on the drivers side some where. I cant seem to find it but it sounds like its coming from around the back spark plug. When i step on the brake before i put it in gear it gets quieter but comes back after a second. I can put it in drive and it idles ok and sometimes i can put it in reverse and it will idle ok for a few mintues before it dies out. I have recently run seafoam through everything and i have double checked the throttle body to be clean. I rechecked valve lash and doublechecked the head bolts and all the spark plugs were tight. I sprayed carb cleaner all around the hoses and didnt notice any difference in idle. I am stumped and dont know where else to look. This motor came from a 01 tahoe its a 5.3l with a 4l60e. anyone have any ideas?
Old Jul 3, 2010 | 05:15 PM
BLWN1's Avatar
Park on hills...
Old Jul 3, 2010 | 09:42 PM
pdsq98gt's Avatar
Make sure it's not your vacuum brake booster leaking. Remove the hose and plug it with your hand or something and see if that helps.
Old Jul 4, 2010 | 12:10 PM
Mtrhd329's Avatar
No difference in idle other than when i disconnect it and plug it back in.
