Cruise control help?
Old Jul 17, 2010 | 10:07 AM
Thealien's Avatar
Originally Posted by garys 68
elmscan, $60, tells you what all your sensors are sending.
Not cruise which is a function I would like out of a scanner I buy.
Old Jul 17, 2010 | 12:24 PM
Thealien's Avatar
My cruise control in now working. Thanks for all the help.
Old Jul 18, 2010 | 02:04 AM
busta9876's Avatar
and the fix was???
Old Jul 18, 2010 | 07:40 AM
Thealien's Avatar
Originally Posted by busta9876
and the fix was???
I was using a simple on off toggle for the off/on
I was using a simple momentary toggle on/off/on for the set/coast and resume/accel functions. While testing I noticed that while I was getting a full 12 volts to the set/coast or resume/accel depending on which direction I was pushing the on/off/on switch. Upun further testing I noticed the opposing side was also getting 3-4 volts. I guess the cheap switch was malfunctioning (rang out with an ohm meter fine?). I removed the resume/accel wire from the switch and now the set/coast functions perfectly. I either need to find a quality on/off/on switch or I am probably just going to get 2 momentary toggle or pushbutton switches, one for each function. For now having the set/coast function working proves that my VSS and TCC sw are both operational.
