Which Wiring Harness and PCM to use?
Old Jul 19, 2010 | 11:07 AM
BanditDave's Avatar
Default Which Wiring Harness and PCM to use?
I posted this in the PCM section but figure I may get a lot more specific traffic here. Sorry if this sounds like a dumb question but I am racking my brain a little on what direction to go with this.
I have a 2008 LY6 block...I am using none of the VVT stuff, only the block and rotating assembly. I plan on switching over the front to all LS2 stuff - timing cover, cam sensor, etc...and with the L92 heads I might use the L76 intake but more than likely a carb style intake with a 90-deg because the throttle body ends up in a much better place for plumming. This is going to be a turbo build, btw, and I am matching it up with a 4L60e transmission and speed density tuning.
That all being said, can I use the harness from a '05/'06 GTO and reprogram for the 4L60E instead of the 65E?
What about if I wanted to use a cable driven throttle body? Could I use an Fbody PCM and would I need to change up the timing cover/cam sensor or could that be made to work with the earlier set up?
Thanks in advance guys...as you can tell I am WAY over thinking it...
Old Jul 19, 2010 | 11:23 AM
-TheBandit-'s Avatar
I didn't know they had LY6s in 2005. Are you sure about the year?
Old Jul 19, 2010 | 12:38 PM
BanditDave's Avatar
Sorry about that...that was a typo...going too quickly. It is a 2008 with 11000 miles.
Old Jul 19, 2010 | 06:36 PM
jamminj007's Avatar
Default Harness
I went with a custom harness. I did everything you talked about doing except went with a 4l80e. Harness ran me 575 all ls3 injectors are the same connection wise? So no mod there. They did have to modify for ls2 timing cover and vvt delete. I also ran a tcu for better tunibilty of the trans. Hope this helps. I used a corvette ls3 intake instead of l92 intake.
Old Jul 19, 2010 | 08:54 PM
BanditDave's Avatar
When you say "they" who do you mean? Who did a harness for you? I am definitely considering the 4L80e for overall strength. I am just not sure how to set this darn thing up.
Thanks,
Dave
Old Jul 19, 2010 | 11:49 PM
BlueZee28's Avatar
PM Pocket, tell him I sent you. He can make any kind of harness you want for any year, TB, transmission, etc.
