lq4 with l92 heads
Old Jul 24, 2010 | 10:33 AM
dec010974's Avatar
Default lq4 with l92 heads
hello to all my ls1tech friends. i hope someone can help me. i want to install the l92 heads on my lq4 but want to if anyone is using the square port truck intake? the reason for this is the placement of accessories like the alternator/power streering bracket & the sanden/kwik performance ac setup. im currently running a stock 5.3/4l60e in a '87 c10 with this setup. there is no interference with the throttle body now. but if i used the low profile l76/ls3intake, there could be interference problems. any help would be appreciated.
Old Jul 24, 2010 | 11:48 AM
deuce4935's Avatar
Which intake do you want to use, the car or the truck rectangle port? If you want to keep using the truck accy drive with the car intake then you will need to get the idler tensioner relocation bracket from Speartech. The idler bracket will allow the accy drive to clear the car intakes throttle body.
