power steering fitting
Old Aug 6, 2010 | 09:20 AM
millman83's Avatar
Default power steering fitting
what adaptor fitting do i need to connect an ls1 power steering pump line to my 71 chevelle steering box?
Old Aug 6, 2010 | 09:38 AM
LS1MCSS's Avatar
Go to Summit and search for power steering adapter fittings. They keep them in stock.
Old Aug 6, 2010 | 11:29 AM
clm69z28's Avatar
For my 72 Chevelle, I modified my LS1 ps hose by cutting off the fitting and and bending the end to fit in the old ps box and reflared a fitting on from a replacement hose for the old ps box. Worked great.
Old Aug 6, 2010 | 01:00 PM
69 Ghost's Avatar
Go for a new box and the hose hooks up directly. You can get a box out of a yard for about $30 and you will not regret it one bit it is a very noticable difference. You will be steering down the road not floating. The one you want is for a B-Body -new Caprice, Roadmaster, Impala SS. The Jeeps also work.......
Old Aug 7, 2010 | 01:21 PM
texas82blazer's Avatar
If you removed the big fitting from the back of your original pump and install it into the back of your new pump your old lines will work fine.
