speedhut gauges
Old Aug 12, 2010 | 07:09 AM
gtpvette's Avatar
I'm using them...
Old Aug 12, 2010 | 03:07 PM
hookemdevils22's Avatar
got 'em in my goat, and absolutely love 'em... wish i knew about them before i bought the autometers for the nova. do yourself a favor, spend some coin and go with the gps speedo. installation is sooooooooooo simple, plus no calibration. the only downside is the fuel gauge is setup for some freaky sender, not the typical 0-90 ohm GM style.
Old Aug 12, 2010 | 07:32 PM
Deserttaco's Avatar
I thought the fuel gauge was programmable? you can use any sending unit you like...
Old Aug 13, 2010 | 07:30 AM
the450r's Avatar
GPS speedo sounds great but what happens when u get out of range of the satellites? or go in a tunnel? my tomtom can barely get a signal with out being next to the window and loses satellites constantly. and the speedo is in a metal and foam padded dash.
Old Aug 13, 2010 | 07:54 AM
Jimbo1367's Avatar
TomTom
Old Aug 13, 2010 | 09:02 AM
Nashty's Avatar
I thought you just used a GPS device to find your true speed and then "dial in" your speedo. After that, you didn't need the GPS signal and your speedo never even used it. Is this correct?
Do they have odometers?
Old Aug 13, 2010 | 09:59 AM
knievel's Avatar
The speedo has an antenna/cord that is routed onto the dash somewhere so it picks up a better signal.
Although it may be possible to lose signal it shouldn't be a big deal or last for more than a minute or two
Old Aug 13, 2010 | 10:41 AM
ya, it's programmable. i connected the wires together to simulate empty (0 ohms) rather than run the thing dry. it's just weird that it's not setup for the typical 0-90 ohm sender.
the gps speedo (further) shortens install time, since you don't have to run wires or a speedo cable to the trans. and like someone said earlier, you can change gears/tires and not worry aboot recalibrating it - it's plug and play (i haven't even calibrated the autometer in my nova, and it's been in there for months). plus they feature 0-60, 1/4 mile, elevation, compass, trip and overall odo, etc. etc.
Old Aug 14, 2010 | 08:25 AM
the450r's Avatar
ok the antenna on the dash sounds alot better. is it easy to hide?
Old Aug 14, 2010 | 11:31 AM
meinthe73's Avatar
Originally Posted by gtpvette
I'm using them...
do you have a thread on your build? the GTM is such a bad *** ride.
Old Aug 14, 2010 | 11:50 AM
speedfreak391's Avatar
I think that looks like a pretty good deal for 6 gauges. The only one missing is boost lol.
Old Sep 17, 2010 | 12:35 AM
  #32
frojoe's Avatar
Old Sep 17, 2010 | 07:12 AM
  #33
Jimbo1367's Avatar
Looking good FroJoe. Any updates on your build?
Old Sep 19, 2010 | 03:35 AM
  #34
frojoe's Avatar
A couple little things but starting within the week I should be cranking back on it for the next couple monthes solid. Wish me good (motivational) luck...
Old Sep 19, 2010 | 06:20 AM
  #35
Jeff Smith's Avatar
Speedhut looks good and not bad price for gauges
Old Sep 19, 2010 | 08:18 AM
  #36
Jimbo1367's Avatar
Good Luck
Old Oct 5, 2010 | 12:53 PM
  #37
InsaneAuto86's Avatar
Just got mine today! Upgraded to the 200mph GPS speedo. Going in my white 95z28:
Old Oct 5, 2010 | 02:31 PM
  #38
NemeSS's Avatar
Originally Posted by knievel
I like the idea of their GPS speedo.... gear changes or tire swaps won't cause any issues!
i usea gps as a speedo now.
it climbs in speed just like a real speedometer. i got it at a flea market for 50$
idk even know what brand it is. came in a white box
Old Jan 24, 2011 | 09:52 PM
  #39
the450r's Avatar
i got mine
Attached Thumbnails speedhut gauges-0124112119.jpg   speedhut gauges-0124112120.jpg
Old Jan 25, 2011 | 09:41 AM
  #40
chevydog66's Avatar
i got mine
Please post some pics after the install.
