carbed LQ4 w/LS3 heads
But the main reason for going carb is I have always wanted a hipo carb motor and this was my chance.
I wouldn't scrap the FI just because the motor isn't running right. Worst case just take it to a local mechanic and have another set of eyes look at it. Chances are it is something basic and will work fine after getting past that hurdle.
A carb does have some drawbacks compared to FI. Nothing as bad as some guys make out. But they can be a bother at times.
from my understanding the victor style carb intakes offer more power over the FI because of the longer runners.
112 LSA: .558/.588 Lift. as of now im using pill #5 with my msd 6010. the msd soft ware is on my laptop. where do i go from here. the guys at msd tech are not customer friendly. the spokesman stated to me that, "trying to tune your car is dangerous. why would u do that? tuners have plenty of experience. you should seek a professional". i wanted to tell this chump, if he's dumb enough to do it, then so am i. I just need some direction ls1tech. lead the way ls1tech fam & i will follow. Thanks in advace. Clark.
here is a quick run down of my engine:
Stock 2001 LS1 short block
Texas Speed Stage 1 ported LS6 heads
Edelbrock Victor Jr intake
MSD 6LS timing box
Texas Speed Magic Stick 3 cam - 237/242 .603/.609
RollMaster double roller timing set
Stock Rockers
Texas Speed push rods
LS7 lifters
Wegner motorsports valley tray with breather
Melling high volume oil pump
ASP 25% underdrive pulley
ARP head bolts
ARP rod bolts
ARP balancer bolt
autokraft oil pan and pickup
Hooker 1 3/4 ceramic swap headers
Holley HP Street 750 double pumper 70 primary, 80 secondary jets.
here is a screen shot of my timing
my car is a manual trans, T56, with 4.11 gears 31 spline 9" rear end.
my car screams dude. pulls hard as hell all the way to 7000 rev limit
