auto to m6
Old Aug 16, 2010 | 05:01 PM
ItalianZ28Stallion's Avatar
Default auto to m6
im transferring a 99 m6 motor tranny over to a 01 auto. wanted to know if the ecu is different and if there will be any problems with the computer going from a 99 to a 01? also is the whole clutch pedal hard to convert?
Old Aug 16, 2010 | 07:10 PM
TheAntiRice's Avatar
you will need the harness and ecu from the m6
Old Aug 16, 2010 | 07:17 PM
getsum27's Avatar
i dont know about the harness but ive always heard you can just tune the computer for the m6
Old Aug 16, 2010 | 07:41 PM
the_merv's Avatar
Veteran: Air Force
You will need the harness for the M6 car, if they are both stock the PCM's can be switched and you will have to do some minor wiring in the auto car.
The 2002 PCM would be the better one, or if you have a good tuner they can get a 2002 tune in that 1999 PCM.
Old Aug 16, 2010 | 11:21 PM
also the miles on the 01 are 65,000 and the miles on the 99 are 160,00 if i switch everything over will the miles on the 01 say 160,000 ?
Old Aug 16, 2010 | 11:42 PM
the_merv's Avatar
Veteran: Air Force
No, the mileage stays with the Cluster.
