ls6 in thirdgen
Old Jan 23, 2004 | 01:43 PM
CaliboyTA's Avatar
Default ls6 in thirdgen
sup guys. im planning on doing a engine swap in my 89 ta. I found an ls6 shortblock with gtp stage 2 heads and cam out of a 01 z06 for a banging price. The only downfall is that it doesnt' come with the ecu and harness. I was wondering if i can use an ecm and harness from any 98-02 fbody and 97-03 c5 or i have to get use the ecm and harness from a z06. thanks
Old Jan 24, 2004 | 12:04 AM
CamaroCain's Avatar
No problem with not using a Z06 harness. Just as long as the Harness and PCM are for the same year or have the same pinouts from the PCM
(i.e. 99-00 are for sure the same, looked it up today.) The main difference will be in the PCM progamming which with heads and cam should be custom tuned anyway especially with a swap like this. Just watch out for differences with stuff like C5's having Throttle Actuated Control module instead of a throttle cable and seperate sensors for TPS and IAC. It just requires a little more effort to make work.
___________
Clint Cain
Old Jan 24, 2004 | 01:39 PM
CaliboyTA's Avatar
cool thanks camarocain
Old Jan 25, 2004 | 03:46 PM
Yellowhammer's Avatar
CaliboyTA
Thanks for asking that question, I am also putting an LS6 in a thirgen. Mine is an 82 Z28.
