New guy, new project
Wiring harness is from the same truck, '01 Silverado/4l60 along with PCM and under hood fuse block.
I am using an NV3500 out of a 1998 Blazer 4.3 along with a Ford 8.8 with Trac-Loc and 3.73 gears from a 1998 Explorer.
I will be using the stock, truck intake and fuel rails. I also will be switching to an f-body oil pan for clearance.
The Celica is very light, around 2700 lbs with me in the car so I can't wait to get the rest of the prep tackled before I can fully dive into the project. Should be a fast 'lil booger.
The only thing that has me daunted a bit is the wiring harness. I've read through the FAQ section covering wiring and my head turns everytime I read more into it.
Luckily the Celica is very old school and the ECU really doesn't control anything but EFI. I can pretty much completely remove it and still have all of my body electrical work.
I am sending my PCM off to lt1swap.com to have VATS, fuel tank pressure and anything else I don't need strictly for the motor to run correctly, disabled.
That really comes down to the question(s) I have.
What exactly can I disable via tune, bare minimum for this engine to run correctly? I am not going to use A/C, will be switching to electric fans and will be a manual trans instead of an auto.
What is the minimum I need for the wiring harness to correctly power the engine? I'd purchase a harness but can't justify the price. Painless wants over $800 bucks for the thing and Speartech is even more. (Although their work is much better I hear.)
For an F-body pan on a truck motor, I take it I need the oil pickup tube. Anything else?
I will be using Autometer Pro-comp gauges for fuel, volts and rpm. Speedometer will be via GPS unit. Should I need any gauges info to the PCM or vice versa?
All I can think of for now, Im sure more will pop up later. Thanks!
I take it I don't need a functioning VSS if I send the PCM out to get reflashed to a manual trans correct?
Take pics and start a build thread. Take lots of pics. Good luck.
Jim
