DBW pedal in Nova
Thanks
I used two bolts with nuts, washers and lock washers to mount everything up. I also smeared gasket sealer on both sides of the bolt heads in the wheelhouse to keep them from taking on water and rusting. The pedal I installed is from a 1998 Corvette.
You are always helpful! That was your 1,500th post!!!!
Oh, I just saw your other post, so this was likely your 1,499th post
You can go to my images in my album to see what the backet looks like as well as the original pedal that I installed on the GTO DBW unit I used. I was going for an orginal look inside so I wanted to retain the 67 pedal.
Hope this helps and let me know if you have any questions.
