LS1 cam kit
Old Sep 6, 2010 | 11:43 AM
Miguel 69Chevelle's Avatar
Default LS1 cam kit
Wat cam should I go with?...can anyone help?......thanks
Old Sep 6, 2010 | 02:19 PM
Clay_SS's Avatar
What are your goals with the car? a little bit more info would help answer your question.
Old Sep 6, 2010 | 03:41 PM
My goal is to have the car sounding good and loud but also fast....more of a street car then anything....the motor is not in the car yet but some people say its eazy to put in the cam when the motor is out...
Old Sep 6, 2010 | 07:57 PM
Clay_SS's Avatar
Texas Speed MS4 makes some good power and sounds amazing. You could call them up and they'd help you pick a cam. bullet cams is another good place to call.
Old Sep 6, 2010 | 09:25 PM
usmcz28's Avatar
This is like asking for shoes over the phone in an other language!
What tranny are you using, rear gear ratio, weight of the car, mods to the engine, compression ratio, heads, work done to the heads, valve springs in the heads, what are your expectations for the car. DO you want performance mild or wild? track car, street/strip, grocery getter.
Man there's a **** ton to consider than just saying hey recommend me a cam that may work in XXXXXX. Every cam is different in every set up, it's like comparing apples and elephants.
