LSX into foxbody?
Old Sep 13, 2010 | 10:52 AM
danielblackst1's Avatar
Default LSX into foxbody?
ive got a 2001 5.3l goinginto a '93 mustang coupe. ive purchased the aje k-member but as ive been looking into putting a 5-speed behind it i havent found much tech so far.
i have a t-5 and have seen the quicktime bellhousing for mechanical linkage, will this work for a cable clutch? can i swap the pivot ball to the other side of the bell housing to accomodate the t-5 clutch fork?
any help would be greatly appreciated!
Old Sep 13, 2010 | 11:34 AM
Alba Gu Brath's Avatar
http://www.mylrs.com/blogs/lrs/archi...ng-part-1.aspx this deals specifically with the 5 speed behind the ls series and the obstacles and unique parts needed and so forth. hope this points you in a good direction.
Old Sep 13, 2010 | 02:59 PM
Default thanks
thanks! thats article looks awesome!
Old Sep 13, 2010 | 03:16 PM
bobo504's Avatar
it would be easier with a 6 speed
Old Sep 13, 2010 | 07:16 PM
Default LSX in Foxbody?
how would i do that?
Old Sep 18, 2010 | 12:44 PM
93teal03lx's Avatar
6speed cross member is sold by AJE and he will give all the details. Basically the mustang is cable clutch and 6speed is hydraulic and the clutch pedal has to be modified to push in the clutch master cylinder. Thats why late model mustang went with the 5speed as its a cable clutch still. I used the tilton master cylinder from summit and modified my stock clutch crossshaft, email if you want details.
thanks
