Help Identifying Power Steering Fitting
Old Sep 16, 2010 | 09:44 AM
sierrac3_s2000's Avatar
Default Help Identifying Power Steering Fitting
We are putting a LS1 in a 89 Toyota Supra and ordered the GMPP front accessory drive which is the same setup as the CTS-V. When we got the PS pump it has what appears to be a push in pressure hose. I am pretty sure I can remove it and put in the standard PS line but it is really close to the pulley so if I can identify this fitting and use it then that would be better. So here is a pic. Any help would be appreciated. If I can't figure it out then I am just going to swap it out for an AN fitting and hope it clears the pulley.
Old Sep 16, 2010 | 07:52 PM
No one has see this type of fitting?
Old Sep 16, 2010 | 08:59 PM
Pocket's Avatar
Take it out and put a more common saginaw fitting in there
You can see its a separate piece with the double hex
Old Sep 16, 2010 | 09:13 PM
Yes I am aware of that as I stated in my original post. I would like to use the push in fitting due to clearances but I have no idea where to get one. That's why I posted.
