LS? into a 62-67 Chevy II
Old Sep 18, 2010 | 05:37 PM
mufflerguy's Avatar
Default LS? into a 62-67 Chevy II
So my thoughts are like this. I currently own a L98 swapped 89 Jaguar XJS Convertible (avatar pic) which is pretty much stock w/ an 89 TPI motor and well built 700R4 and a 2800 stall lock-up converter with a 3.23 posi. The car is heavy at 4010lbs but runs a respectable 13.68 @ 99 mph in full, emissions legal street trim. Anyway, the car may be sold and I would like to get back into a 62-67 Chevy II which I should be able to keep around 3000lbs. I would like to build a durable, very mild mannered, supercharged drivetrain making about 550 hp. I want to keep fuel economy in mind and I plan on using an od automatic. I am very happy with the 700R I have in the jag. It has been trouble free for the 3 years its been in this boat. What I don't like about it is the 1-2 gear ratios. To big a drop for my liking. Is there an LS? series engine that a 200R4 will bolt up to. These can be built to handle lots of power ( GN guys) and the 1st gear ratio and the od ratio are, IMO, a little better. What LS combination will bolt up to a 200R and what would be an easy to build, economical to build and trouble free LS platform to meet these goals. Thanks for your time guys.
Rob Wade
Mufflerguy
See some of my work at http://s268.photobucket.com/albums/jj24/mufflrguy/
Old Sep 18, 2010 | 06:00 PM
Jimbo1367's Avatar
IIRC. there's a Company that makes a different 1st gear (maybe 2nd too, my memory isn't what it used to be, sorry) ratio not as steep for I believe the 700R4. I would think they can be used in a 4L60e too. I forget what mag it was in though. Try the tranny section.
