Low drivers alternator belt squeeks
Old Sep 28, 2010 | 09:29 PM
68Problemchild's Avatar
Default Low drivers alternator belt squeeks
Put an L92 into an old 68 camaro. Used vette type set up and put the original L92 alternator in a drivers side low position. The low alt is just not sitting right. I think its touchig the frame and wont sit flush on the motor. I have it on 3/4 inch spacers but the belt squeels when I blip the throttle.
Photo:
http://www.flickr.com/photos/41575483@N07/4886234783/
Ideas?
1. Notch frame?
2 Grind / Trim Alt?
3. Raise eng mounts?
Does GM make a smaller alternator that fits in place of the original vette/LS3 like a race alternator?
Thanks in advance.
Old Oct 17, 2010 | 10:28 AM
-TheBandit-'s Avatar
How did you even manage to install the alternator if it's up against the frame?
GM has smaller alternators. The 4th gen f-bodys are smaller, but I don't have a good measure on how much smaller.
Old Oct 17, 2010 | 10:36 AM
Cam72aro's Avatar
The squealing could be related to the tensioner not having enough tension. Put a wrench on the tensioner and give it more tension while blipping the throttle and see if the squeal goes away.
Old Oct 17, 2010 | 06:40 PM
Jimbo1367's Avatar
good idea !
Old Oct 17, 2010 | 06:48 PM
Cam72aro's Avatar
good idea !
I had this problem with my ac and was able to determine the tensioner as the problem.
