th400 question
Old Oct 26, 2010 | 02:49 PM
texas82blazer's Avatar
Default th400 question
I have a 82 4x4 k5 with a 5.3/th350 if I swap to a th400 is there anything different besides the th350 is mechanical kickdown and the 400 is electric.
Old Oct 26, 2010 | 03:04 PM
-TheBandit-'s Avatar
The TH400 also needs a manifold vacuum connection.
Old Oct 26, 2010 | 03:27 PM
speedtigger's Avatar
Old School Heavy
The TH400 is longer than the Th350 and takes a different drive shaft yoke if I remember correctly. You will also need to move or modify your transmission cross-member unless you can find one out of a truck with a TH400 to swap in.
Old Oct 27, 2010 | 12:46 PM
ya im not worried about that im just talking about going from the 5.3 with a
th350 does anything change when going to the th400 like flywheel and stuff with the engine.
Old Oct 27, 2010 | 02:01 PM
Old School Heavy
Not if you are using the same torque converter.
