Vin #
Old Nov 10, 2010 | 06:52 PM
Floyd99's Avatar
Default Vin #
Could someone tell by the Vin # if this is a Trans Am, WS6, or Formula, the seller says it is a WS6, might be a clone. The Vin # 2G2FV22G812114012. Thanks
Old Nov 10, 2010 | 07:11 PM
Floyd99's Avatar
Sorry I Forgot to list year, it is a 2001, Thanks
Old Nov 10, 2010 | 07:46 PM
Earl Filter's Avatar
Probably posted in the wrong section, but I can help ya:
Using this...
http://www.compnine.com/vid.php
I found this.
http://www.compnine.com/vid.php?vin=2g2fv22g812114012
It's a WS6. That is straight out of GM's RPO code database (like running a VIS from the GM service system).
CalEditor's Avatar
Hey look it is all 3 Trans Am, WS6, & Formula,
Branded Title: Yes
Warranty Block: Yes
FE9 - 50-STATE LOW EMISSION VEHICLE
G80 - LIMITED SLIP TORSEN REAR DIFFERENTIAL
GU5 - REAR PERFORM AXLE, 3.23 RATIO
LS1 - 5.7 LITER SFI V8 ENGINE
M30 - AUTOMATIC TRANSMISSION
MX0 - TRANSMISSION, 4-SPEED AUTOMATIC
NF7 - FEDERAL LOW EMISSION
QFK - TIRES, P275/40ZR17 SPEED RATED
UB3 - RALLY GAGES W/TACHOMETER
V12 - POWER STEERING COOLING SYSTEM
V73 - VEHICLE CERTIFICATION U.S.
WS6 - RAM AIR PERFORM.& HANDLING PKG: * RAM AIR INDUCTION SYSTEM * FUNCTIONAL AIR SCOOPS * 17" HIGH POLISHED ALUMINUM WHEELS * P275/40ZR17 SPEED RATED TIRES * SPECIFIC LOW RESTRICTION DUAL EXHAUST SYSTEM * SPECIFIC TUNED SUSPENSION * POWER STEERING COOLER
WS9 - FORMULA OPTION
Y82 - TRANS AM OPTION
Old Nov 10, 2010 | 08:00 PM
Floyd99's Avatar
Thanks for the info. lots of help.
Old Nov 10, 2010 | 08:12 PM
Pony Exp.305's Avatar
Thanks..That s cool to get inform from vin#..
