2004 GTO Wiring Harness Mod
Here's where I stand. I have deleted the following items.
Blue connector
#23, 25, 28, 65, 68
Green connector
#34, 45, 52, 53, 64
Basically the rear O2 sensors, EVAP, fuel pressure, fuel level sensor.
Are there more to delete?
I am also tying to figure out what wires I need coming into the car or route to relays.
So far I understand it to be...
Blue connector 33, 58, 34?,
Green connector 42, 50, 9, 33
Is this correct? Am i missing anything?
What pin is the AC request? is it 18 on the green connector?
And where is the low speed signal for the fans?
Do the other wires coming into the car just get removed?
Thanks
Mike
Also, did I read somewhere that one side of the injectors need a pink wire to them instead of the green wire?
Thanks
7 - ignition 1 voltage
9 - delivered torque signal
17 - requested torque signal
Do these extra wires just get removed?
