Your thoughts
Old Nov 19, 2010 | 11:49 PM
ranloachi's Avatar
Default Your thoughts
I've just jumped into this LS world with both feet and am causing a lot of debate in the process. I had an early demise to my first generation small block in my G-body. So I decided to replace it with an LS . Here's the debate that is surrounding my project. What power will this motor make. I've gotten an LY6 engine which is a 6.0 iron block motor with a 9.6 compression ratio. The motor has the L92 heads already but I'll be adding a cam speced out as 243/259 with .624 lift on both sides and 116 LSA. I willl be running a carb with about 12lbs of intercooled procharged air. I also have a methonal injection system. I am thinking of going with a 2" primary tube header into a true dual 3" exhaust. That is the bases for some heated debate between my friends and coworkers at my job. I'm hearing as low as 400s and someone is even thinking high 6s. So I figured the best people to come up with an accurate figure would be people in the LS world. So what do u guys think????
Old Nov 20, 2010 | 01:04 AM
Bullitt4110's Avatar
Its hard to say, but for reference my Z06 that I sold had a 383, stock heads, 232/240 117 cam, 1-3/4 headers with 2.5" catted x-pipe, methonal and a Vortech Si trim with 13psi made 637rwhp
Old Nov 20, 2010 | 01:20 AM
chuckd71's Avatar
No matter what anyone says here it won't really solve the debate unless they have your exact same setup. You're going to have to dyno that thing.
Old Nov 20, 2010 | 09:17 AM
Jimbo1367's Avatar
Get out of my head !!!
Old Nov 20, 2010 | 08:29 PM
ranloachi's Avatar
Ok I think we can all see who really needs help.
Old Nov 20, 2010 | 10:01 PM
brian.harmon1974's Avatar
agreed
Old Nov 20, 2010 | 11:12 PM
3pedals's Avatar
