1990 notch swap throttle question
Old Nov 24, 2010 | 03:57 PM
Tunink's Avatar
Default 1990 notch swap throttle question
I have a 1990 notch with a 408 swap carb conversion.
My question/problem is that my throttle is not opening all the way. I am using an aftermarket cable and bracket. Using a stock pedal.
Any advice to help getting this thing to go full throttle?
Old Nov 24, 2010 | 04:01 PM
ebk06's Avatar
I remember reading that the stock auto cable from the foxes worked fine. Not sure if thats the case for a carb setup though.
Old Nov 24, 2010 | 09:44 PM
Z284thgen's Avatar
Is the pedal all the way to the top when carb/TB is shut
Old Nov 25, 2010 | 10:05 AM
Tunink's Avatar
I believe so. When the pedal is to the floor the front butterflies are open not quite all the way and the rear are barely open
