ls1 water pump
Old Dec 3, 2010 | 07:42 AM
Bobby G's Avatar
Default ls1 water pump
Are the camaro and corvette water pumps the same, I thought the corvette set up was closer to the block, also can I use the lq4 power steering pump on the corvette with a corvette res?
Old Dec 3, 2010 | 12:29 PM
MeanYellowZ's Avatar
The water pumps interchange fine. The water pump pulley is wide and the belt rides further out on the f-body setup and further in on the Corvette setup. The truck power steering pump is not a type II power steering pump like the vette and f-body and does not work well with an external reservoir setup.
