LS! crate motor
Old Dec 5, 2010 | 05:53 AM
wanderlodge's Avatar
Default LS! crate motor
What size throttle body and injectors should I use for my LS1 motor I am looking for a newer intake probably LS6 any info is appreciated
Old Dec 5, 2010 | 05:54 AM
davidws6's Avatar
I think the ls6 will support only the stock size TB .
Old Dec 5, 2010 | 06:39 AM
Default LS1 crate
What does the throttle body size mean, for my LS1 which intake would be the best I have none now so I would like to buy the one that is the best and that gives me the most HP this is very confusing I seem to get a lot of part answers
Old Dec 5, 2010 | 08:44 AM
chuckd71's Avatar
Have to make sure the ports on the heads match the intake, so do that before you spend money. Also, unless you spend money on every other type of bolt on the difference in power isn't going to be that great and even then it's still a pretty expensive $$/ hp item. You are probably getting a lot of different answers because you are asking a vague question with no info about what you are trying to do.
