99 Camaro to 69 Camaro
Old Dec 10, 2010 | 11:01 AM
jasycz28's Avatar
Default 99 Camaro to 69 Camaro
Well doesn't look like I will get what I want for my 99 Camaro so rather than give it away I have been thinking about pulling out the motor, tranny, seats, and brakes for my 69 Camaro then just parting out what I have left. So my questions is what else could I use from the 99 for the 69 without a ton of fabrication?
Suspension?
Rearend?
Old Dec 10, 2010 | 12:55 PM
Drewhelm's Avatar
You can use the brakes front and rear. Take caliper brackets, calipers, hoses, and rotors.
You can also use the rear end if you want to run the Camaro wheels under your 69. The 4th gen rear is longer and will require the removal of the mounting bracketry and welding of universal leaf spring mounts. Relatively cheap and easy. Keep in mind the 4th gen rear end is a 7.5 and not the best choice for our cars. You can (I have done it) install the rear end and run the Camaro wheels on it under a 69. You could put the seats and seatbelts in the car, as well. For that matter the dash and console, as well.
