05 5.3 LM7 charging module?
It's taped to the battery cable, but more importantly, it's hooked to the "ind ctrl", pin 15, green PCM terminal.
If I dont need the module, where should that wire connect in a standalone harness?
The way I understand, you only need it if you are using the factory alternator controlled by the PCM.
I wired it into the charging circuit. Looks like the alternator defaults to 13.8 V even if the thing fails, so guessing it wont hurt.
Any other input on this?
