motor question need help asap
Old Dec 15, 2010 | 11:14 PM
onebadsvt00's Avatar
Default motor question need help asap
im putting a 2005 silverado 5.3 on my T/A but i wanted to know if the oil pan on it is the same as the ls1, kuz it doesnt want to line up the motor mounts so do i need a ls1 oil pan or that one should fit?????????
Old Dec 17, 2010 | 07:36 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
The truck oil pan won't clear the steering rack & is also way deeper than the f-body pan so ground clearance would be an issue. Go with the f-body oil pan & you will be just fine. Make sure you also get the pick-up and windage tray for the f-body pan.
