98 Harness VSS Question... Help!!!!
If thats the case then yes you can. Make sure by popping the VSS out of the 91 trans and see if its a gear drive or hall effect reluctor. If its a 4L60E, it should be the reluctor and plug in directly, no need to switch connectors
4x4 versions use an adapter/extension harness using the same connector. These are common on S10's in JYs
Thanks!!!
If you do cut and splice be aware the colors switched
http://www.lt1swap.com/pictures/12_b..._radio_vss.gif
Lt grn/Blk: Low
Ppl/Wht: High
http://www.lt1swap.com/pictures/100_1780.jpg
Ppl: Low
Yel: High
Lt grn/Blk: Low
Ppl/Wht: High
Ppl: Low
Yel: High
Thank you sir!!!
