LS-1 with T56
Old Jan 6, 2011 | 06:55 PM
wanderlodge's Avatar
Default LS-1 with T56
I am installing a LS-1 with a T56 behind where have you guys mounted and which clutch master cylinder are you using
Old Jan 7, 2011 | 12:23 AM
bczee's Avatar
what are your putting this into ?.. for most 60's and 70's GM cars. the 4th Gen F-Body OEM master with a adpater plate can be used (which is what I am using).
But it all depends on what car your working with ?
Old Jan 7, 2011 | 12:33 PM
rotor vs. piston's Avatar
I got a complete package out of a '04 GTO and used the master cylinder from that w/ a home made adapter for my Toyota pickup. Also had to swap the push-rod that connects to the pedal... works great and feels natural.
Old Jan 7, 2011 | 12:37 PM
Smo's04Gto's Avatar
Same as above into a 72 nova made my own adapter.
Old Jan 7, 2011 | 01:21 PM
vannatta20's Avatar
I used a wilwood 7/8 master. Its great and very compact. Make sure you have a good pedal/arm ratio when doing this. The higher the rod is attached to your clutch pedal the more leverage.
