Donor 99 camaro to 63 impala
THe Question:
How much of the the Donor can I use and place in the impala( rearend, disc etc)? How much of the wire harness do I pull?
Before I start parting it out, I want to use as much of the donor as possible.
Thank You in Advance.
Im not shure it the fuse box is connected to the engine harness or not on an f-body. i think it is someone ealse confirm this.
Just unplug the connectors in the pass side kick panel, and the three on the pass side strut tower. Thats all you need to use for the engine, you can send that off to be setup to plug in and play. Or you can do it yourself, just cut one of the fuse boxes out of the camaro under the hood to use.
I'm not sure about rearend width differences, but i'm sure you can make it work with some cutting and welding.
Make sure you buy a billet carrier bearing for the driveshaft, I'll bet $$ you will obliterate the stock one or even a stock replacement one as soon as you hit the throttle!
