68 camaro ls3/t 56 header question....
Old Jan 16, 2011 | 06:04 PM
ls3cam's Avatar
Default 68 camaro ls3/t 56 header question....
This is my first LS swap, which is a 68 camaro w/t56 and LS3.
Will newer Camaro headers work with this swap?
Whats everyone been using?
thanks for any info....
Old Jan 16, 2011 | 07:43 PM
Irish350's Avatar
id imagine the clearance issues (steering, mounts, frame, struts, brakes, trans linkage, where applicable) are totally different between the two. Ive never dealt with a 1st gen, but id imagine you'd be better off with BBC headers made for that car with lsx flanges, or swap specific headers (which there could very well be for that car).
When you're looking at all the threads in the conv. section click the 'search this thread' button at the top right and have at it; youre certainly not the first. there are some CRAZY 1st gens here
Old Jan 16, 2011 | 08:08 PM
tsnow678's Avatar
Buy some Dynatechs! They are ceramic coated long tubes and look great. They will set you back $412 including shipping. They have the O2 bungs already welded in.
Old Jan 18, 2011 | 12:22 PM
ls3cam's Avatar
thanks for the info tsnow,420.00 shipped..but looking at mid feb before they ship.....
Old Jan 18, 2011 | 02:59 PM
tsnow678's Avatar
Where did you check on the headers from? I got mine within 3 days from Summit. Speedway has them so does Jegs. Call Dynatech direct, they are in the middle of changing their part numbers so if you cannot locate them at one distributor that might be why. Be prepared to buy an MSD spark plug boot kit for numbers 5 & 7 cylinders as the number 3 tube goes straight back and will cause interference with the stock ends. The MSD kit is part number 3301. It is an adjustable boot kit that will allow you to bend the wire to the appropriate angle to clear. I think it was like $6.00 for a set of two. I went ahead and bought 2 kits to be on the safe side.
Dynatech • 975 Hyrock Blvd • Boonville, IN 47601 • 800-848-5850
I wanted the Kooks headers but $900+ was not in the budget. Look at my thread if you want to see some close ups of the dynatechs. My thread is under "conversions and hybrids" listed as "LQ4/T56 in my 69 Camaro". If you need any further information let me know.
Old Jan 19, 2011 | 07:25 PM
ls3cam's Avatar
tsnow,Dynotech said mid feb,summit said end of this month.The shipping was 25.00 cheaper through summit,ordered through summit.
Pistons will not be here till mid feb,so i will waitthanks for the boot info.
Old Jan 19, 2011 | 07:57 PM
68Problemchild's Avatar
Default Headers LS into 68 Camaro
Its not just as simple as headers. It all has to work together.
Get a matched set.
Headers must match:
Mounting plates, subframe caps, engine mounts, tranny choice, alternator (will hit subframe), front accessories, AC clearance. The headers need to wrap around and clear the steering box.
You will spend twice as much money without a plan.
Locate what some one else used and use every part they did or you will buy parts 2 times over.
On headers, Hooker has a matched set for LS into a 68 Camaro
As does Edelbrock.
This may help:
http://www.flickr.com/photos/41575483@N07/
Long road and expensive.
Old Jan 19, 2011 | 08:21 PM
bmf5150's Avatar
I went with s&p motor mounts,trying to figure out what long tube headers will work with them!!
