what do i need from a doner 99 silverado
So far I told him full swap with all accessories and not to cut any wires. Also need the computer, is there anything else I should get? Thanks
DO you want to go manual?
Is the donor truck 2wd or 4wd?
If you want to use a 4l60e and the truck is 2wd as well as your car, take the transmission. If the truck is 4wd and you application is 2wd you cannot use the transmission unless you plan a full rebuild job on it and swap the input shaft.
Can someone tell me what wiring I need if I wana build the harness myself.
