LS1 in a 86 K5 Blazer
Old Jan 17, 2011 | 03:10 PM
blue00ZZleeper's Avatar
Default LS1 in a 86 K5 Blazer
Ok so I did a little searching and couldn't find much on swapping a LS1 into a 86 K5 blazer. We have a 02 corvette pullout minus trans. I know I'll need different motor mounts, and a trans adaptor. I want to use the stock PCM as well. It will be running a 700R4 trans and I'm not sure on the transfer case. If I forgot any info let me know. If anyone has any info or could help at all I'd appreciate it. This is a buddy of mine's project and he needs as much help as he can get. Thanks!
Old Jan 17, 2011 | 09:24 PM
Nobody has tried this yet? lol I thought they had LSX motors in EVERYTHING so far. Any advice from the truck swap guys?
Old Jan 17, 2011 | 09:50 PM
WOOS1's Avatar
There are lots of swap threads over on the CK5 forum. I have one going over there myself. For the 700R4, you can run an NP-208 T/C. If you want to take full advantage of the swap, a 4L60E mated to a NP-241 T/C from an 1990-1991 suburban or K-5 will be required. I am currently pondering an LQ9/4L80E/NP-241 swap.
Old Jan 17, 2011 | 11:14 PM
Do you have a link to your thread? I was wondering about motor mounts, wiring problems...basically everything needed parts wise to make the swap. I'm not sure what T/C he has for his truck...iirc its a NP/208. I run the N/P-241 in my jeep and love it!
Old Jan 19, 2011 | 02:05 PM
jkade72's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=438563
Let me know what you need to know.
Old Jan 22, 2011 | 08:33 AM
69_YENKO's Avatar
Originally Posted by jkade72
awesome build! I'm about to do a 86 suburban LQ4 swap.
