electrical problem
Old Jan 17, 2011 | 11:39 PM
bfrank79's Avatar
Default electrical problem
Ok. I cranked my ly6 for the third time. It was idling fine for a couple minutes then all of the sudden it died and I lost power to everything on the dash. After some meter checking I figured out that I was not getting power to anything that is key on powered. I assuumed I blew aa fuse but they were all good. Does anybody have any idea what's wrong. Oh yea the vehicle is a 79 c10.
Old Jan 18, 2011 | 06:45 AM
Pop N Wood's Avatar
Could be a blown fusible link, failed relay or just a connection/fuse that came loose. A bad ignition key is another possibility.
This should be a relatively easy one to find. Just start at the battery and start tracing along the power line until the volts go away. The intermittent problems are the hard ones to find.
Hopefully it is a one time failure and not a short causing something to overcurrent.
Old Jan 18, 2011 | 09:33 AM
lizeec's Avatar
Default Check Again
Check your fuses by using a ohm meter, do not go by just checking for continuity or a visual inspection, fuses can look fine and can give you a good continuity rating till you put them under a load, the best method as I mentioned is to ohm them out.
Old Jan 18, 2011 | 12:22 PM
bfrank79's Avatar
it may also help to know that I connected my battery backwards by accident the night before and saw smoke coming from one of the fused links. My best guess is that is the problem but i dont really know how to replace one of the links
Old Jan 18, 2011 | 01:14 PM
Pop N Wood's Avatar
Most auto parts stores carry them. They go by the guage of the wire. You just cut the old one out and splice in the new one. Here is a write up with details if you need them.
http://bebrs.pie-dabas.net/Webs/Terr...ble%20Link.pdf
This place sells them
http://www.madelectrical.com/catalog/fusible-link.shtml
I prefer replacing fusible links with an in line fuse, but the fusible links do have some advantages
