Throttle cable
1)The plastic sheath can be dremel cut (very carefully of course!) just before the grommet at the firewall (engine bay side). When you decide how long the cable really needs to be, cut the plastic, being sure to leave about a 3/8" plastic coming from the grommet in the engine bay. Then, you buy a 3/4" metal sleeve, just large enough to fit over the plastic throttle sleeve. Slide both ends of the cut plastic throttle sleeve into the metal sleeve. I used just a bit of rubber gasket seal between the plastic sleeve (carefully) inside the metal sleeve to keep it all together.
2)You can shorten the metal/cable by cutting at the gas pedal to the correct length, leaving enough cable so that there is the proper travel. After you initially cut the metal cable (I used a dremel for this, too...makes a CLEAN cut), work the ferrule off of the discarded piece. I redrilled the ferrule so that it could be slid back on to the 'new' end of the cable. Then, tighten/squeeze the ferrule with pliers.
Before you cut the cable, you might plan on leaving enough cable beyond the ferrule so that a knot can be tied after it to hold it on.
Just an alternative for you.
